Simple, meaningful data
The Basic Data folder provides easy access to frequently-run reports. You can select the entire folder to create a basic report for a given form that includes easy-to-read, meaningful data and appropriate key elements to ensure report accuracy.
The Basic Data folder contains:
- Clinical data for a form.
- Text values of items rather than database codes, as well as most of the available date formats.
- Several query items that you can use to identify sites, subjects, and visits.
