Access Cognos
- Log in to InForm using Internet Explorer or Mozilla. Do not use Chrome.
- Click Reports.
- If you want to run a standard report, on the left, select Team content, and select the folder where the standard reports are stored.
Caution: To protect study data, be sure to save reports only in a study folder under the Team content folder. This ensures that users can only see the report data if they have access to the InForm study from which the data is pulled.
Reports saved outside of a study folder are public and can be seen by any user with Publisher rights. In this case, users with access to your reporting instance can see the data in the report regardless of whether they have the rights to see the data in InForm. You should only save reports outside of a study folder in rare cases in which you want to share the data more openly. For more information, see Save reports to the Team content folder sparingly.
or
If you want to create a report using Query Studio, on the left, click New, click Other, and click Query Studio.
