#1 - Injection
Injection vulnerabilities occur when data is sent into an interpreter via an interface specification and the party submitting the data does not perform checks on the data to ensure only the expected actions are performed by the interpreter on the data. SQL, Code, Command, Log, Path Transversal (XML) are all possible types of injection based upon the interpreter used in the container.
