Review the audit trail
You can view the audit trail in different ways, depending on what task you're completing. You can also view audit trail data by running the Audit Trail Report in the Reporting and Analysis module.
If you're entering data on a form:
- Click the audit trail icon (
) for an item.
If you're changing or reviewing form data:
- Click the data entry field for the item.
- On the Data Value(s) page, select a change date and time from the Audit Trail list.
- Review the details in the Reason for Change section.
or
- On the left side of the Data Value(s) page, click Audit Trail.
