How do I create an Oracle Account for signing in to HS Learn?
You need an Oracle Account to access the training in HS Learn. This Oracle Account is a separate account required to access HS Learn; it does not use the same credentials you use to log in to your study.
- Go to HS Learn using the following URL: https://oracle.learn.taleo.net/healthsciences
The Sign in page appears.
Note: Wait until HS Learn loads completely before adding a bookmark. Don't bookmark the HS Learn Sign in page.
- Under Don't have an Oracle Account?, click Create Account.
- Complete all the required fields in the form.
- Enter the email address where you received your HS Learn Course Assignment email.
While you can create an Oracle Account with an email address that is longer than 50 characters, HS Learn has a 50-character limit. If your email address exceeds this limit, you won’t be able to log in to HS Learn.
Send a request to your study administrator to be re-assigned to the training with an email address that does not exceed the 50-character limit.
- Click Create Account.
- Check your email for a confirmation message.
Note: If you don't receive a confirmation email, or you have any issues creating your Oracle Account, contact Oracle Account Support using the following URL: https://www.oracle.com/corporate/contact/help.html
