Cognos Reporting application server
Component |
Description |
Operating systems |
Supported Microsoft Windows platforms: Windows Server 2012 R2 Standard (64-bit). For the recommended patches for Windows operating systems, see Windows patch recommendations for the InForm software. |
Reporting |
For information on the supported Cognos versions and patch numbers, see the InForm Reporting Cognos Installation Guide on the Oracle Help Center. Note: For a list of the historical Cognos versions supported, see the Reporting & Analysis tab in the Oracle Phase Forward Product Technology Compatibility Matrix available for download from MOS Article 180430.1 (Oracle Health Sciences Applications Supported Technology Stack). For InForm documentation relating to a version of Cognos listed as supported, contact Oracle Global Support. |
LDAP |
Oracle Directory Server Enterprise Edition 11g. Release 1 (11.1.1.7.2). Note: The Oracle Directory Server can be installed on either the Microsoft Windows or the Linux operating system. For more information, see the Oracle website, the Oracle Directory Server Enterprise Edition documentation, or your Oracle database documentation. |
Database Client |
Supported Oracle versions: Oracle Database Client 12.1.0.2 (32-bit). For details on required components and patchsets, see Oracle client component and patch requirements for the InForm application server. Required for the Cognos Report Server and the Cognos Content Manager. Note: The Cognos Analytics 11 Reporting application server was validated using Oracle Enterprise Edition 12.1.0.2. |
Other |
Note: Because the Cognos Analytics 11 Reporting application server requires the 32-bit Oracle database client, you cannot install all the InForm software components on a single development server. For information about supported deployment options, see the Installation Guide.
