Client computers—Microsoft Windows
The InForm 6.3.1 client was validated using Microsoft Windows 7, Windows 8, and Windows 10. For more information, see the Installation Guide.
Browsers |
Display resolution |
Microsoft Excel |
A version compatible with your operating system is required to view reports exported from the Data Viewer or Cognos Reporting. |
Adobe Acrobat |
Adobe Acrobat Reader DC or higher to view reports in PDF format. |
