Editing menu section details
You can edit the details of menu sections and change their position in the Home menu.
- Click Admin (
). - On the left, click Manage Custom Menu Items.
- Select the menu section to edit.
- Edit the fields as necessary, and click Submit.
Field descriptions for the Menu Section form
Field
Description
Notes
Menu Type
The type of menu:
Default: Section Title.
Title
The title of the section that appears in the Home menu.
Submit
Creates your new section, which appears in the Home menu.
Delete
Removes the menu option from the Home menu.
This button is enabled after you create a section.
Default: Disabled.
Move Up
Moves the menu option up one position in the Home menu.
Default: Disabled.
Move Down
Moves the menu option down one position in the Home menu.
Default: Disabled.
Close
Terminates the Add New Section process and returns you to the Manage Custom Menu Items page.
