View Diagnostic Logs page
On this page, you view the log of the background services and applications that support IRT. This log can help you diagnose problems that are related to automated or scheduled functions, such as data transfers and drug ordering.
Fields on this page
This table describes the default fields for this page. Your study might require different fields, and those fields could have different names.
Field
Description
Notes
Report functions
Interactive Grid
Changes the grid display of the page.
Layout for Print Mode
Displays the log in a print-friendly format.
Create Filter
Specifies conditions for filtering information.
Save Current Report
Saves the current page layout after filters have been applied.
Export/Save
Saves and exports the diagnostic log.
ID
The ID number of the group of functions.
READ-ONLY
Date/Time (GMT)
The date and time when the group of functions occurred.
READ-ONLY
Group
The group of functions that was written in the diagnostic log at the same time.
READ-ONLY
Severity
The severity of the group of functions:
- DEBUG
- INFO
- WARNING
- ERROR
- FATAL
READ-ONLY
Source
The background application that wrote the line in the diagnostic log.
READ-ONLY
User ID
The ID number of the user who performed the transaction.
If the system performed the transaction (for example, if the system ran a scheduled task), the User ID is (null).
READ-ONLY
Message
A message that describes the running task.
READ-ONLY
Exception
A line of code that contains an error. For example, if a C# exception causes an error, the Exception field displays the code that contains the error.
READ-ONLY
