Manage Custom Menu Items page
On this page, you create menu sections and items that appear in the Home menu.
Fields on this page
Field |
Description |
Notes |
Menu Type |
The type of menu:
Default: Section Title. |
Title |
The title of the section that appears in the Home menu. |
Submit |
Creates your new section, which appears in the Home menu. |
Delete |
Removes the menu option from the Home menu. This button is enabled after you create a section. |
Default: Disabled. |
Move Up |
Moves the menu option up one position in the Home menu. This button is enabled after you create a section. |
Move Down |
Moves the menu option down one position in the Home menu. This button is enabled after you create a section. |
Close |
Terminates the Add New Section process and returns you to the Manage Custom Menu Items page. |
Field |
Description |
Notes |
Menu Type |
The type of menu item:
Default: Upload File. |
Title |
The title of the menu item. |
File |
Uploads a file to add as a menu item. This field appears if you selected Upload File from the Menu Type section. |
URL |
The URL to add as the menu item. This field appears if you selected Use existing URL from the Menu Type section. |
Common URLs |
Opens a Select common URL drop-down list. This field appears if you selected Use existing URL from the Menu Type section. |
Display for roles |
A list of user roles. Select the roles whose users can view the new menu item. |
Default: All roles are deselected. |
Submit |
Delete |
Move Up |
Move Down |
Close |
Terminates the process and returns you to the Manage Custom Menu Items page. |
