Setting up InForm to receive data
You must identify whether InForm is ready to receive data from IRT. Ensure that InForm is fully configured, online, and ready to receive data from IRT before you set Inform Is Up to Yes.
- Click Admin (
). - On the left, click Manage Inform Setup.
For descriptions of the fields on this page, see Manage Inform Setup page.
- Do one of the following:
- If InForm is ready to receive data from IRT, from the Inform Is Up drop-down list, select Yes, and click Submit.
IRT files will be sent to InForm.
- If InForm is not ready to receive data from IRT, from the Inform Is Up drop-down list, select No, and click Submit.
Files will not be sent to InForm.
Note: If InForm is not available for an extended period of time, you must reset the Inform Is Up option to No. When InForm is available again, set the option back to Yes. The files that are created while InForm is not available are sent to InForm at scheduled intervals (typically, 15-minute increments).
