Editing menu item details
You can edit the details of menu items and change their position in the Home menu.
- Click Admin (
). - On the left, click Manage Custom Menu Items.
- Select the menu item to edit.
- Edit the fields as necessary, and click Submit.
Field descriptions for the Menu Item form
Field
Description
Notes
Menu Type
The type of menu item:
Default: Upload File.
Title
The title of the menu item.
File
Uploads a file to add as a menu item.
This field appears if you selected Upload File from the Menu Type section.
URL
The URL to add as the menu item.
This field appears if you selected Use existing URL from the Menu Type section.
Common URLs
Opens a Select common URL drop-down list.
Display for roles
A list of user roles.
Select the roles whose users can view the new menu item.
Default: All roles are deselected.
Submit
Creates your new section, which appears in the Home menu.
Delete
Removes the menu option from the Home menu.
This button is enabled after you create a section.
Default: Disabled.
Move Up
Moves the menu option up one position in the Home menu.
Default: Disabled.
Move Down
Moves the menu option down one position in the Home menu.
Default: Disabled.
Close
Terminates the process and returns you to the Manage Custom Menu Items page.
