Run the Script for RFID 27629203
If you use Oracle DMW 2.5 with Oracle TMS and your study was created in a release prior to Oracle DMW
2.4.8.1, you must run a script to update the p-package of TMS-enabled tables to resolve
bug number 27629203. Before you run the script:
- Plan a maintenance window and run the script for a select group of TMS-enabled studies, rather than all studies
- Check in work areas and data models for studies impacted by this script
- Plan to run the script on a computer with an Oracle client that can connect to the DMW database server using SQLPlus
If you previously installed Oracle DMW 2.4.8.1 patch or later before upgrading to Oracle DMW 2.5, you do not need to run this script. Skip this procedure.Parent topic: Upgrading to Oracle Life Sciences Data Hub Release 2.5
