Upgrade to Oracle LSH 2.4, then 2.4.7, then 2.4.8 or 2.4.9
To upgrade to Oracle LSH 2.5, your Oracle LSH system must use 2.4.8 or Oracle LSH 2.4.9. See the following steps for details.
All procedures in this chapter are required for each upgrade path (if not done already).- If using Oracle LSH 2.1.x, 2.2.x, or 2.3.x, upgrade to Oracle LSH 2.4 by following instructions in the upgrade chapter of the Release 2.4
Oracle Life Sciences Data Hub Installation Guide. If you use Oracle Health Sciences Data Management Workbench (Oracle DMW) 2.3.1, upgrade to Oracle DMW 2.4 by following the upgrade instructions in Oracle Health Sciences Data
Management Workbench Installation Guide. See the Oracle Health Sciences
Life Sciences Warehouse site to access the guides:
http://docs.oracle.com/cd/E54418_01/index.htm - Once you upgrade to 2.4, upgrade to 2.4.7 following the instructions in document 2137430.1 on My Oracle Support (with the exceptions noted in the Oracle LSH 2.4.8 installation instructions, document 2383498.1 on My Oracle Support). If you use Oracle DMW 2.4, upgrade to Oracle DMW 2.4.7 by following the instructions in document 2137432.1 on My Oracle Support.
- OnceOracle LSH and Oracle DMW use release 2.4.7, upgrade Oracle LSH to release 2.4.8 or 2.4.9. For 2.4.8, follow the steps in document 2383498.1 on My Oracle Support. For 2.4.9, follow the steps in document 2429893.1.
Parent topic: Upgrading to Oracle Life Sciences Data Hub Release 2.5
