Build_Exe_Cfg_Function
This function is not called by the system. Use it only if you need an additional function that another function can call.
For example, in the SAS adapter, the pre-execution function calls a procedure buildSasExeContent to generate dynamic components of a SAS configuration for execution. The binary components are returned in a list of BLOBs and the ASCII components are returned in a list of CLOBs.
Parent topic: Object Execution Functions and Procedures
