Call the Create Adapter Domain API
To create an Adapter Domain, call the public API CDR_PUB_ATK_ADAPTER.CREATEADAPTERDOMAIN. Its signature is:
PROCEDURE createAdapterDomain( p_api_version IN NUMBER ,p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE ,p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE ,p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL ,x_return_status OUT NOCOPY VARCHAR2 ,x_msg_count OUT NOCOPY NUMBER ,x_msg_data OUT NOCOPY VARCHAR2 , pio_adapterDomainNaming IN OUT NOCOPY cdr_naming_version_obj_type ) ;
It has one mandatory parameter, PIO_ADAPTERDOMAINNAMING, of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values as follows:
- company_id = Enter your company ID; see Getting Your Company ID.
- obj_id = null
- obj_ver = null
- object_type_rc =
'$OBJTYPES$ADAPTERDOMAIN' - name = Enter a name for the Adapter Domain.
- namespace_obj_id = null
- namespace_obj_ver = null
- namespace_start_obj_ver = null
- namespace_end_obj_ver =
cdr_def_constants.cdr_max_def_object_version - owning_location_rc = null
- checked_out_flag_rc = null
- checked_out_id = null
- object_subtype_id = null
- description = Enter a description of the Adapter Domain.
- copied_from_company_id = null
- copied_from_obj_id = null
- copied_from_obj_ver = null
- ref_company_id = null
- ref_obj_ver = null
- object_version_number = 1
- status_rc =
'$NAMING_STATUS$INSTALLABLE' - validation_status_rc = null
- version_label = null
Parent topic: Creating an Adapter Domain
