Call the Create Program API
To create a Program definition and an instance of it, call the API CDR_PUB_DF_PROGRAM.CREATEPROGRAM.
Its signature is:
PROCEDURE CREATEPROGRAM(
P_API_VERSION IN NUMBER,
P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE,
P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL,
X_RETURN_STATUS OUT VARCHAR2,
X_MSG_COUNT OUT NUMBER,
X_MSG_DATA OUT VARCHAR2,
PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE,
PI_CDRPRGOBJTYPE IN CDR_PROGRAM_OBJ_TYPE,
PI_CREATEOBJECT IN VARCHAR2,
PI_INSTANCE_SUBTYPE_ID IN CDR_NAMINGS.OBJECT_SUBTYPE_ID%TYPE,
PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL,
PI_INSTCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL
Enter Parameter values as follows:
- PIO_SOURCECDRNAMING. Enter CDR_NAMING_VERSION_OBJ_TYPE values that apply to the Program definition, as follows:
- company_id =
Enter_your_company_ID - obj_id = null
- obj_ver = null
- object_type_rc = null
- name = '
Enter_a_name_for_the_Program' - namespace_obj_id =
Your_WorkArea's_obj_ID - namespace_obj_ver = 1
- namespace_start_obj_ver = 1
- namespace_end_obj_ver=
cdr_def_constants.cdr_max_def_object_version - owning_location_rc = null
- checked_out_flag_rc =
'$YESNO$NO' - checked_out_id = null
- object_subtype_id = null
- description =
'Enter_a_Description_for_the_Program' - copied_from_company_id = null
- copied_from_obj_id = null
- copied_from_obj_ver = null
- ref_company_id = null
- ref_obj_ver = null
- object_version_number = 1
- status_rc =
'$NAMING_STATUS$INSTALLABLE' - validation_status_rc = null
- version_label = null
- company_id =
- PI_CDRPRGOBJTYPE. Enter CDR_PROGRAM_OBJ_TYPE values that apply to the Program definition, as follows:
- company_id =
- obj_ver = 1
- tech_type_id =
Enter_your_Tech_Type_ID - manual_validation_flag_rc =
'$YESNO$NO'
- company_id =
- PI_CREATEOBJECT =
BOTH - PI_DEFCLASSIFICATIONCOLL = null
- PI_INSTCLASSIFICATIONCOLL = null
Parent topic: Creating a Program Definition and Instance
