Check in the Parameter
You must check in the Parameter so that other objects can reference it.
Call API CDR_PUB_DF_PARAMETER.CHECKINPARAMETER. Its signature is:
PROCEDURE CHECKINPARAMETER( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRNAMING IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Enter values as follows:
- PIO_BASEOBJECT. Enter CDR_BASE_OBJ_TYPE values to identify the variable.
- company_id =
Enter_your_company_ID - obj_id =
Enter_the_Parameter's_obj_id - obj_ver = 1
- object_version_number = 1
- namespace_obj_id =
Enter_your_Adapter_Area's_obj_id - namespace_obj_ver = 1
- company_id =
- PI_COMMENT = null
Parent topic: Creating a Parameter
