Save the Variable ID for Future Use
The input/output Parameter PIO_NAMING returns the Object ID (obj_id) and version number (obj_ver) of the Variable.
You will need this ID when you define a Parameter based on this Variable. Be careful to save a meaningful name with the ID, as you may have many Variables.
If you are creating Tables in your adapter, you can create Variables and Table Columns at the same time. You do not need to create Variables first.Parent topic: Creating a Variable
