Activating the Hierarchy and Making it Usable or Unusable
When you have finished defining the hierarchy and its levels, make a hierarchy active and usable.
When a hierarchy's Active flag is set to Yes:
- You can add terms to the levels in the hierarchy.
- However, you cannot add levels to an active hierarchy.
- You can never change the setting back to No.
When a hierarchy's Usable flag is set to Yes:
- You can assign the hierarchy to object subtypes.
- You can set it back to No as long as it is not assigned to any subtypes.
- Activate and Make Usable
To activate a hierarchy, do the following: - Make Unusable
If you prefer not to make the hierarchy usable at this time, do the following:
Parent topic: Creating and Maintaining Hierarchies
