Defining Connections
A Connection provides a username and password that Oracle Life Sciences Data Hub uses to access a remote database.
Oracle LSH encrypts the passwords.
To use a Remote Location, there must be at least one Connection defined for it. You, the administrator, can define shared Connections available to all users with normal security access to the defined Remote Location. In addition, any Oracle LSH user with an account and password on the remote location can define his or her own Connection through the Preferences link (see "Setting Preferences" in the Oracle Life Sciences Data Hub User's Guide for instructions). User-defined Connections are available only to the user who defined them.
To define a Connection:
You can change the security and classifications of the Connection through the items in the Actions drop-down list. By default, the Connection inherits the user group assignments of the Remote Location. If the user group assignments for the Remote Location and Connection are different, the user must have access to both in order to use the Remote Location/Connection combination.
Parent topic: Registering Locations and Connections
