Execution Statuses
Execution statuses provide more detailed information than job statuses. For diagnostic purposes, the system displays the highest execution status a job reached, even if the job ended in failure.
- Submitted
Submitted is the initial execution status of the job on the job queue. - Initializing
The job is waiting for OWB operator processing to begin. - Serializing
The job is waiting for another instance of same program to complete. - Backchain
The system is performing backchain processing; examining the executable instances upstream to check if they have backchain Execution Setups defined and if so, if their source data is more current than their target data, and rerunning qualifying jobs as necessary to maximize data currency. - Recovering
The system is rolling back data written to tables in the previous execution of same program that did not complete successfully. - Pre-Execution Function
The system is executing a technology-specific pre-execution function. - Obtain Service
The system is obtaining a service instance appropriate for the Program's technology type and specified priority, given the service instances currently available for the technology type. - Pending Logon
The system is waiting for the Program to start and connect to the Oracle Life Sciences Data Hub database. - Executing
The Program has connected to the database and is executing. - Completing
The system is performing post-execution table completion processing. - Complete
The job has successfully completed processing. - Fail Backchain
The job failed during backchain processing. - Fail Logon
The job failed to connect to the Oracle Life Sciences Data Hub database. - Failed
The job failed at a phase not specified by one of the other failure statuses. - Rolling Back
The system is rolling back target tables to their pre-job state due to the job's execution failure. - Rolled Back
The system completed rolling back target tables to their pre-job state due to the job's execution failure.
Parent topic: Monitoring Jobs
