General Job Information
The system displays the following information about jobs in the search results at the bottom of the Job Administration screen:
- Job ID
The system-generated ID of the job. You can click on the Job ID hyperlink to view execution details for the job. - Job Status
The current status of the job. - Name
The name of the executable object—Program, Load Set, Report Set, Workflow, or Data Mart—that generated the job. - Execution Setup
The name of the Execution Setup used to generate the submission form for the job. - Work Area
The name of the Work Area within which the job was executed. - Object Type
The object type of the executable that generated the job—Program, Load Set, Report Set, Workflow, or Data Mart. - Start TS
The timestamp of the beginning of the job. - End TS
The timestamp of the end of the job. - User
The user who submitted the job for execution.
Parent topic: Job Information
