LSH Data Unblind User
Only the LSH Data Blind Administrator can assign this role to users. This role does not provide access to any tabs in the user interface. Users assigned to this role typically also have the LSH Consumer role.
Users with this application role can do the following, if they have normal object security access and the blinding-related object security privilege noted:
Permanently unblind data in Table instances (also requires an object security role with the Unblind operation on Table instances)
Change the status of an output from Blinded to Unblinded (also requires an object security role with the Unblind operation on outputs)
The LSH Data Unblind User application role is not required in conjunction with the Read Unblind operation on either Table instances or outputs. Users can have an object security role that includes the Read Unblind operation on Table instances (to run a job on unblinded Table instances) and/or outputs (to view the results of such a job) without having the LSH Data Unblind User application role as well.
Parent topic: Oracle Life Sciences Data Hub Application Roles
