Modifying Object Subtypes
To modify a Subtype, click the corresponding Update icon in the Manage Subtype screen.
You can modify the following Subtype characteristics:
- Name
- Is Active. If selected, this Subtype is available for use during definition of objects of this Object Subtype.
- Is Default. If selected, this is the default Subtype for objects of this Object Subtype.
Parent topic: Creating and Maintaining Object Subtypes
