Programming Languages
Oracle Life Sciences Data Hub is integrated with adapters for programming languages to enable data transformation.
A defined object called Program is also required. Oracle LSH Programs typically read data from source tables and write data into target tables. The source and target tables reside in Oracle LSH. Oracle LSH Programs can also work without interacting with tables, if the requirement is such.
When a Definer creates an Oracle LSH Program, the only Program types available to him or her are those that correspond to the particular adapters to which the Definer has security access.
Parent topic: About Adapters
