Querying and Viewing Lookups
To view a lookup, or reference codelist, query for it as follows. Further information is available in the online help.
See Modifiable Lookups for a list of Oracle Life Sciences Data Hub lookups you can modify.
The following information is displayed for each value:
- Code is the internal name for the value.
- Meaning is the text that appears on the user interface, exactly as it appears here.
- Description is an explanation of the value.
- Tag is an optional descriptor.
- Effective Dates. The From column contains the date the value was created in your location. The To column may contain a date; if so, this is the date on which the value became or will become unavailable for use. If there is not a date in either column, the value is in effect.
Parent topic: Adding and Modifying Lookup Values
