Report Set Jobs Do Not Produce Any Output when using SAS 9.2
If you are using SAS 9.2 and find that your Report Set jobs fail and do not generate any output, you must install the one-off patch 6993271.
See "Apply Required Oracle Applications Patches" in the Oracle Life Sciences Data Hub Installation Guide for details on how to install the patch.
Parent topic: Job Execution Problems
