SAS IDE Client
(CDR$SAS_IDE_CLIENT) The access level is User. This lookup allows users to set a preference for which SAS client to use. There is one predefined value: SAS PC, which allows users to use PC SAS for Windows. If you want users to be able to use SAS Enterprise Guide, for example, add another meaning value of SAS EG with a code value of $SAS_IDE_CLIENT$SAS_EG.
If you do not want your users to use PC SAS and do not want the SAS IDE Client option to appear in User Preferences, delete the SAS PC value. If you want to add it again later, you must enter its code value as: $SAS_IDE_CLIENT$SAS_PC.
To delete the value, select it and select Delete from the Edit menu. Do not delete the lookup itself.
Parent topic: Modifiable Lookups
