Set Processing Type for OC Data Extract Incremental Adapter
This profile allows you to set the default processing type for the incremental Oracle Clinical data extract adapter, which uses incremental-mode processing and is therefore faster than the regular OC data extract adapter, which uses full-mode processing. You can specify transactional processing with or without audit.
  1. Log in. See How to Log In to Oracle Applications Profile Forms.
  2. In the Profile field, enter LSH: OC Incremental Adapter Default Processing Type
  3. Click Find.
  4. In the Site column:
    • Select $PROCESSTYPES$TRANSWAUDIT to use transactional processing with audit.
    • Select $PROCESSTYPES$TRANSWOAUDIT to use transactional processing without audit.
  5. In the File menu, select Save and Proceed. The system displays a message that the transaction is complete.
  6. Click OK. The transaction message pop-up disappears.
  7. Click the X in the upper right corner of the System Profile Values window to close the window.
