Starting, Stopping, and Checking the Distributed Processing Service
The Oracle Life Sciences Data Hub Distributed Processing (DP) Server passes jobs—executions of user-defined Programs and Data Marts and internal Oracle LSH jobs requiring XML Publisher—to the external engines that process them.
You must install and start the DP Server on every computer where you have a processing engine installed. See Setting Up Services for further information.
You must then start the service on the computer where it is required. The scripts required for starting, checking, and stopping the DP Server are provided with Oracle LSH. See Setting Up the Distributed Processing Server and the Oracle Life Sciences Data Hub Installation Guide for instructions for copying them to the DP Server home directory in each location.
- Login Name
You must log in as cdr_dpserver. - Starting the Distributed Processing Server Service
You can start the Distributed Processing Server Service by following the steps in this procedure. - Checking the Distributed Processing Server Service
After you have installed and started the service, use the script checkJSapps to check that it is running. - Stopping the Distributed Processing Server Service
Parent topic: Stopping and Starting Services and Queues
