Stopping, Starting, and Enabling the Job Queue
A job queue is required on the database to pass jobs from Oracle Life Sciences Data Hub to OWB.
The job queue is enabled by the Oracle LSH post-installation concurrent processing job. You must explicitly start it using the instructions below.
The scripts are located in $cdr/patch/115/sql/.This section includes the following topics:
- Starting the Job Queue
To start the job queue, connect asappsto run the script. - Stopping the Job Queue
You can stop and disable the job queue by connecting asappsto run the script. - Enabling the Job Queue
After you have started the job queue (or it has been started during installation) you must enable the job queue by connecting asappsand running the script.
Parent topic: Stopping and Starting Services and Queues
