Submission Parameters
Submission parameters are Parameters defined for the particular Program, Load Set, Report Set, Data Mart, or Workflow executed by the job.
- Name
The system displays the name of the Program, Load Set, Report Set, Data Mart or Workflow instance that was executed. - Type
The object type of the object listed in the Name column. - Value
The value in effect at submission.
Parent topic: Job Execution Details
