6 Defining Variables and Parameters
See Defining Table Columns for information on defining Columns.
- About Variables, Parameters, and Columns
- Defining Variables
Oracle LSH creates Variables automatically based on the Oracle columns or SAS variables that you load or upload from an external system. In addition, you can create Oracle LSH Variables manually, either directly or as part of the process of creating a Table Column or a Parameter. - Using the Variable Properties Screen
This section contains the following topics. - Defining Columns
- Defining Parameters
- Using the Parameter Properties Screen
- Setting Up Parameter Value Propagation
You can set up Parameter value propagation only in the context of a Workflow or Report Set. - Defining and Using Parameter Sets
- Defining Programatically Generated Lists of Values and Value Validation
- Modifying Parameters
