Keep Container and Object Names Short for Integrated Development Environments
Although names can contain up to 200 characters, the maximum length of a file path is 256 characters in Windows.
When you open an integrated development environment (IDE) such as SAS or run a SAS Program on your personal computer, Oracle Life Sciences Data Hub uses the actual full file path for Source Code definitions, Table instances, and the SAS runtime script. If the full file path exceeds this length you get an error and cannot open the IDE or run the Program. You can use a package to limit object name size or display an error when an object's file path is too long; see Customizable Naming Validation Package.
The full file path begins with the Oracle LSH username of the person who opens the IDE followed by the directory name cdrwork. It also includes all Subdomains in the path, if any. (The maximum number of Subdomains is 9. This number is configurable.)
- Source Code definitions. The path for Source Code definitions is:
username>cdrwork>Domain_name>Subdomain_name(s)(0-9)>Application_ Area_name>Program_definition_name>Source_Code_definition_nameversion_number>fileref>source_code_filename - Table instances. The path for Table instances is:
username>cdrwork>Domain_name>Subdomain_name(s)(0-9)>Application_ Area_name>Work_Area_name>program instance name>program version>Table_Descriptor_libname>Table_Descriptor_SAS_name> - SAS runtime script. The path for x is:
username>cdrwork>Domain_name>Subdomain_name(s)(0-9)>Application_ Area_name>Work_Area_name>Program_instance_name>version_number>setup
Parent topic: Naming Objects
