Launching Oracle SQL Developer
When you click Launch IDE from an Oracle Life Sciences Data Hub PL/SQL Program, the following takes place:
- If yourOracle LSH PL/SQL Program contains a Source Code instance with a PL/SQL package in it, then Oracle LSH compiles your PL/SQL package.
If there are any bugs in your PL/SQL package, Oracle SQL Developer fails to launch and an error message related to the bug appears on the Oracle LSH screen. - Oracle LSH launches Oracle SQL Developer. Connect to the Oracle LSH database using your database user credentials.
If you cannot find an Oracle LSH database connection to which you can connect, you may have to set up the connection. Contact your System Administrator for more information. - Table instances mapped to your Program's source Table Descriptors appear as synonyms in Oracle SQL Developer; for example, if the Oracle Name of a source Table descriptor is
DEMOGthen there will be a synonym by the nameDEMOGin Oracle SQL Developer. - Table instances mapped to your Program's target Table Descriptors appear as empty
tables in Oracle SQL Developer.
You can edit, compile, and execute your PL/SQL package in Oracle SQL Developer and these tables reflect the results of your data manipulation. However, the data is not written to Oracle LSH Table instances.
If you do not want to lose changes you made to the PL/SQL package in Oracle SQL Developer, you must upload your package back into the Oracle LSH PL/SQL Program's Source Code instance before you exit Oracle SQL Developer. See Modifying Source Code for instructions.
Parent topic: Setting Up Oracle SQL Developer or SQL*Plus as an IDE
