Modifying Constraints and Indexes
When you create a Table instance from a Table definition, the system copies the definition's constraints and indexes to the instance instead of referencing them there.
Therefore, any changes you make to the Table instance in the Work Area affect only the instance.
Normal Oracle database rules apply to making changes in table constraints. Oracle prevents changes that might be destructive. For example, you cannot change the Column that constitutes the Primary Key unless the new Column's Nullable attribute was previously set to No.
In most cases you cannot modify an installed Table instances's constraints without dropping and replacing the Table instance during a Full or Partial Work Area installation, resulting in the loss of all data. This is not allowed in a Table instance with a validation status of Production.
If you must modify a Production Table instance's constraints, you may be able to define a new Table instance with the required constraints and write a Program to migrate the data into it, if the data and the new constraints are compatible.
If you modify the Table definition through the instance, the system points the instance to the new version of the definition, so the changes apply to the instance as well as the definition. If you modify the definition directly in its Domain or Application Area, the changes affect only the definition, but you can upgrade instances to point to the new version.
See Defining Table Constraints and Indexes for further information.
Parent topic: Modifying Table Definition Properties
