Modifying Domains, Application Areas, and Work Areas
Domains, Application Areas, and Work Areas should be part of a carefully designed organizational structure; see "Designing an Organizational Structure" in the Oracle Life Sciences Data Hub Implementation Guide.
Name. You can update the name at any time.
Description. You can update the description at any time.
Usage Intent. This property belongs to Work Areas only. See Changing a Work Area's Usage Intent.
Subtype. Select a subtype according to your company's policies.
Classification Values. You can change the classification values at any time. Use caution, however, because this may have the effect of changing the classifications of some or all objects contained in the Domain, Application Area, or Work Area, and all their children, grandchildren, and so on. See "Designing a Classification System" in the Oracle Life Sciences Data Hub Implementation Guide.
Usage Intent. Work Areas have one additional attribute that you can update.See Cloning Work Areas for Testing and Production for further information.
To change the usage intent, do not click Update. Instead, select Upgrade Usage Intent from the Actions drop-down list and click Go.
Parent topic: Creating Container Objects
