Running and Saving System Reports
Information on where to run each report is included in the section on the report.
You can run a report only if you have security access to the screen from which it is launched and to the metadata included in the report.
To generate a system report:
After saving the report to your local machine, you can add it as a validation supporting document to a defined object, if appropriate. The report is then stored in Oracle LSH.
Parent topic: System Reports
