Using the Data Mart Properties Screen
If you are working in a Work Area, you see the properties of both the Data Mart instance and the Data Mart definition it references. If you are working directly on the definition in an Application Area or Domain, you see only the properties of the definition.
See also Figure 8-1.
See Modifying Data Marts for information on modifying Data Marts.
