Using a SAS Format Catalog
If your SAS code operates on data sets that require SAS formats for the proper expression of their data, you must include the formats in yourOracle Life Sciences Data Hub SAS Program (see Defining SAS Programs).
When you create a SAS Program in Oracle LSH that needs to use an Oracle LSH SAS Format Catalog, do the following:
You can now use any of the formats in your Program. At execution they are added to your work library and you can call them by name from the primary source code, for example:.
Parent topic: Writing SAS Primary Source Code
