Using Tables as Pass-Through Views
For Table instances that are the target of an Oracle-technology Load Set, you can specify in the Process Type drop-down list that the Table instance is a pass-through view. No processing type is required because the system does not write data to the Table instance. Instead, you use the Table instance as a view to see data in the source system.
For further information, see About Oracle Tables and Views Load Sets.
Parent topic: Data Processing Types
