Using the Workflow Properties Screen
If you are working in a Work Area, you see the properties of both the Workflow instance and the Workflow definition it references. If you are working directly on the definition in an Application Area or Domain, you see only the properties of the definition.
See Modifying Workflows for information on modifying Workflows.
See also Figure 9-1
Parent topic: Defining Workflows
