Classification Hierarchies for Use in Searching Only
In this example, there are additional keyword hierarchies defined for use in searching for object definitions, instances, and outputs. Most are used only with objects of a particular type or subtype, as described in this section. Most are defined as Mandatory and have a blank default value, so that the Definer must select a classification value for each individual object. Keyword hierarchies do the following:
- Label Programs by Technology Type
- Label Load Sets by Type
- Label Data Marts by Format
- Label Programs by Purpose
- Label All Primary Objects with a Data Category
- Label Outputs and Data Marts for Submission to Regulatory Agencies
- Label Data Marts to be Sent to Research or Business Partners
Parent topic: Classification Example
