About Data Blinding, Blind Breaks, and Unblinding
Some sensitive clinical data must be protected from viewing during the course of a clinical trial; for example, treatment codes that would reveal which patients were receiving which drugs.
Oracle LSH supports data blinding in Oracle LSH Table instances and in all reports generated using one or more blinded Table instances as a source. Users with special privileges can unblind data (for example, at the end of a trial) or break the blind temporarily as required during the trial. Separate privileges are required to run and view reports generated on blinded and unblinded data.
All Table instances have a Blinding flag. You must set this flag to Yes to indicate that the Table instance may contain blinded data. If the Blinding flag is set to Yes, Oracle LSH maintains two sets of rows: one set for the real data and another set for dummy data, effectively partitioning the table in the database.
When a user loads data or runs a Program that reads from or writes to a Table instance whose Blinding flag is set to Yes, he or she must indicate in the submission form whether the job is running on real, blinded data or on dummy data. The system reads from and writes to the partition the user indicates. The options for the particular user submitting the job are limited by his or her own blinding-related security privileges; see Blinding-Related Security Privileges.
Oracle LSH cannot ascertain whether data in an external system requires blinding or not. You must set up your security system so that only people who understand the issues and the source data can run Load Sets that may load sensitive data.Table instances also have a Blinding Status attribute. Table instances whose Blinding flag is set to Yes can have a Blinding Status of either Blinded or Unblinded to indicate the current state of the data. Table instances whose Blinding flag is set to No can have a status of either Not Applicable (the default) or Authorized, which makes it possible for a nonblinded Table instance to be the target of a Program that reads from one or more blinded Table instances; see Reading from Blinded Table Instances and Writing to Nonblinded Table Instances.
Oracle LSH allows you to keep data securely blinded and also allows the following:
- Blind Break. A blind break is access to real, sensitive data that remains
blinded to other users; it is a single execution of a job that reads from or writes
to one or more blinded or unblinded Table instances. The Program may produce a
report that displays the real, sensitive data. Even the log file of the job may
contain sensitive information. One privilege is required to execute the job, and
another privilege is required to view any resulting outputs. All blinded Table
instances involved remain blinded and the same privilege is required to run the same
executable again on the real data.
The Blind Break privilege also allows access to real, blinded data through the Browse Data feature, through an integrated development environment (IDE), and through data visualizations; see Blinding-Related Security Privileges below.
- Unblind. Users with unblind privileges can permanently unblind data in a Table instance. They can also reblind the Table instance if necessary. A separate privilege is required to view reports generated on unblinded data.
For further details on how Oracle LSH handles blinded data, see "Execution and Data Handling" in the Oracle Life Sciences Data Hub Application Developer's Guide.
Parent topic: Security for Blinded Data
