Definitional Object: Workflow
For example, you can create a Workflow to load data from two systems, wait until both loads are successfully completed, and then run a Program that writes data from both systems into a single set of combined Tables and generates a Report Set on the combined data.
You can also insert Notifications into a Workflow. Notifications are sent to recipients you specify either to simply inform them of something, such as the fact that the Workflow has just generated a report on fresh data, or to request their approval, for example of a load of lab data before the data is included in a statistics analysis report generated later in the Workflow. In the case of approval requests, the Workflow waits for a response. You define the next Workflow step in the case of both an approval and a rejection.
For further information, see "Defining Workflows" in the Oracle Life Sciences Data Hub Application Developer's Guide.
Parent topic: Automating Multiple Processes
