Design Decision Summary
You should set standards for promotion to the Quality Control and Production validation statuses for definitions and instances of Tables, Programs, Load Sets, Report Sets, Workflows, Data Marts, and Business Areas. Oracle LSH automatically promotes component objects such as Parameters, Notifications, and Overlay Templates when you promote their containing object. However, you may also want to explicitly validate these object definitions and move them to a Domain for reuse.
If you are using object subtypes, you can set different validation requirements for different subtypes of the same object type.
Oracle LSH provides two types of requirements to use: Supporting Information and Security. You can create additional required operating procedures if you so choose.
Parent topic: Validating Objects and Outputs
