Project 123 Domain User Group
The Project 123 user group is assigned to the Domain that includes all of Project 123.
The privileges granted to a user through his or her role(s) in a user group assigned to a Domain apply by default to the Application Areas and Work Areas in the Domain, unless the user group is explicitly unassigned from a particular container.
Therefore, the roles assigned to the Domain user group should allow only the operations required to allow the proper use of the object definitions in the Domain library. See Domain Libraries for a discussion of the recommended usage of Domain Libraries.
The Project 123 user group includes the following two roles:
- Librarian/Project Programmer. The Librarian (or Project Programmer) role
allows maintenance—including creation, modification, and deletion—of the object
definitions of all types in the Domain library. The Create operation is required to
move an object into the library.
We recommend that these definitions be developed in the Domain's Application Areas and moved into the library only after they are stable, validated, and approved for reuse. They should then need very little maintenance. Assign this role to only a few people.
- View All Definitions. All Programmers and Data Managers working on Project 123 need the View operation on all object definitions in the Project 123 Domain library so that they can reuse those definitions. Therefore, all users who have the Programmer or Data Manager role for any study in the Project 123 Domain also belong to this user group with the role View All Definitions.
Parent topic: Example User Groups
