Retired Object Rules
Oracle LSH enforces the following rules on objects with a validation status of Retired:
- You cannot create an instance of a Retired object definition. (However, existing instances of a definition whose status is changed to Retired can still have an active validation status and function as before.)
- You cannot modify an existing object instance to point to an object definition whose validation status is Retired.
- Executable object instances whose validation status is set to Retired cannot be run.
If you decide that you want to use a retired object, there are three ways to do so:
- If you have the necessary privileges, you can reactivate the object, setting its validation status back to whatever it was immediately before retirement.
- Copy the retired object. The system sets the validation status of the new object to Development.
- Create a new version of an object by checking it out (object definitions only).
Parent topic: Retired
