Secondary Objects Contained in Organizational Objects
Only secondary objects that are contained directly in organizational objects or instance objects require security operations. Security for operations on secondary objects contained in primary object definitions, such as Source Code, Source Code instances, and Table Descriptors, is controlled by the Modify operation on the containing primary object (such as a Program definition).
